Mystery carb linkage
As part of wheeling and dealing to change to EFI, I have ended up with a linkage crossbar which is not set up for a standard 911. It is the one in black, with the cad colored one for reference. As you can see, the lever which rotates the arm is located in a different location - would be to the right, if installed otherwise normally, and at a different angle. And is a different shape.
![]() ![]() ![]() Anyone know what motor this was for? Perhaps it is a 914-6 factory part? Walt |
The 914/6 throttle linkage still pivioted off the transmission so it has the 911 layout
Bruce |
