-   -   2.7 CIS Engine Rebuild (http://forums.pelicanparts.com/911-engine-rebuilding-forum/566151-2-7-cis-engine-rebuild.html)
MJP 07-27-2011 03:01 PM
Your engine looks great! What fuel pump did you decide on, and where did you mount it? I don't see a fuel return line off the fuel manifold, do you have a regulator with a return line mounted somewhere?
Joost73 06-28-2014 03:44 PM
Nice to see others are doing the same thing, are you leaving the 912 motor stuts in?
pemz0r 06-29-2014 11:09 AM
I am.
That way I can easily convert it back to a 912, just in case I want to sell it as an original 912.
It's a 3 gauge and I am not planning on adding the other gauges too. I will most likely build a gauge set up that I can fit into the radio cut out.
