Pluging Tensioner oil line
I may need to run the engine with the Hydraulic type tensioner (non-pressure type), but I only have the newer oil line for the pressure type tensioners. Is there a cap that will plug off the cam tower line to the tensioner? In other words can it be capped?
Old 10-09-2010, 12:26 AM
If you have the drop line to the tensioner you could cut it, removre the the connector and put a BB under it and it should seal like the fuel rail on a Carrera.
Bruce
Old 10-09-2010, 05:06 PM
I'd hope there would be a cap, but sounds like a new oil line for the cam tower would the way.
Old 10-09-2010, 06:17 PM
