sda sda is offline
thermostat required
I put in a 993 tank and oil line and I believe the thermostsat stuck .
I only track this car do I need a thermostat ?
mtr/bstr
Old 10-07-2010, 06:12 PM
Its a VERY good idea to retain one, even for race engines.
Most people are simply not disciplined enough to carefully warm the engine before running it hard and I've seen my share of popped coolers and worse.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 10-07-2010, 07:52 PM
sda sda is offline
what are the dangers if the oil isn't warmed up . And what would you consider warmed enough ?
Old 10-07-2010, 11:26 PM
You will pop the cooler.
180 deg F is warm enough to race.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 10-08-2010, 09:21 AM
It's a 914 ...
stownsen914's Avatar
Doesn't do much for engine longevity either to run a cold engine hard. I run a thermostat in my track only car, and it usually warms up to 180* in a lap or 2.
Scott
Old 10-09-2010, 10:10 AM
