JED
ARCSinAK's Avatar
3.6 pricing/conversion thoughts
Found a 3.6 from a 90 c-2. I am in Hawaii so I would have to buy it site un seen, owner say he has the DME and harness. In a worst case scenario what would the core and electronic be worth. I have a 80sc and would like do the conversion, any ballpark numbers on related costs would be great, I am aware of the clutch and engine tin.
thanks for your time-
JS
Old 10-06-2010, 06:02 PM
Timmons and or Patrick motorsports have kits and individual parts available. In addition to the engine you need conversion flywheel,engine harness and DME,body adapter harness,oil return tube,power steering block off,additional oil cooling added to the body and an expensive exhaust system ( a budget system can be constructed using 993 HEs) and a heat crossover connector if wanting heat( Not likely)and some adaption of your AC hoses to the 993 AC compressor. Minor work to throttle linkage and tin trimming and spacers under the rear motor mounts are easy. I did it several years ago for about $2500 plus engine but I have seen prices quoted much much higher. I am a retired tech and did all myself so no labour in that price
1980 911 SC 3.6 coupe sold
1995 993 coupe
1966 Mustang Shelby clone
1964 Corvair Spyder Turbo gone
2012 Boss 302
Old 10-06-2010, 06:47 PM
