Pluging Tensioner oil line
I may need to run the engine with the Hydraulic type tensioner (non-pressure type), but I only have the newer oil line for the pressure type tensioners. Is there a cap that will plug off the cam tower line to the tensioner? In other words can it be capped?
If you have the drop line to the tensioner you could cut it, removre the the connector and put a BB under it and it should seal like the fuel rail on a Carrera.
Bruce |
I'd hope there would be a cap, but sounds like a new oil line for the cam tower would the way.
