7.0:1 > 11.3:1 > 7.0:1
964 case, what is behind this plug
This is a 964 case (993 motor) Can anyone tell me what is behind this plug? Can I remove it without disturbing chain ramps etc? (It appears to be a potential location for a turbocharger drain. I'd like to investigate...)
Old 11-07-2010, 07:33 PM
MBEngineering's Avatar
HI Jim
the bolt holds the chain ramp, also the one above, use the drain plug or fit a 3.3 turbo return pump in the L/H cam and a small catch tank to the bottom of the turbo to return from, the oil can cool in there before re-turning to the oil tank.
regards mike
Old 11-08-2010, 12:55 AM
Thanks Mike. I'll go back to my original plan now and use the drain plug.
Old 11-08-2010, 06:40 AM
