tadd's Avatar
Measuring bearing clearences
Ok, so I know of two ways to determine rod and main bearing clearance...
1. Torque up rod or case, measure with dial bore gauge. Measure bearing thickness with a cone anvil mike. Measure journal with flat anvil mike. Do math.
2. Insert bearings, torque rods or case. Measure with dial bore gauge. Measure crank. Subtract.
I've always done #1 cause I always end up digging a ditch in the bearing (never fails ) and I've been told that once a bearing is crushed it will never 'bite' as well again.
I've also been told that proper clearance isn't measured unless the bearing is under crush since they are designed slightly egg till crushed.
Thoughts anyone... No, plastigauge is not acceptable .
Tadd
1967 912 with centerlocks… 10 years and still in pieces!
Old 10-18-2010, 04:30 PM
Ubi bene ibi patria
Hawkeye's-911T's Avatar
Bump!
Old 10-19-2010, 10:28 AM
What's wrong with plastigage?
Tom Butler
1973 RSR Clone
1970 911E - Sold but Never Forgotten
914-6 GT Clone
Old 10-20-2010, 10:28 AM
tadd's Avatar
Tom:
Plastigauge can be all over the place. The manufacture of the string itself is pretty accurate, but there is a lot of noise in the 'squishing' and 'reading'.
There have been a lot of articles on this topic... one link for your viewing pleasure.
Plastigage Versus Micrometer - Accuracy Test - Car Craft Magazine
tadd
Old 10-20-2010, 02:13 PM
abit off center
cgarr's Avatar
Those bore gauges are good but its really an art to using them. You could have guys measure the same bore and come up with 5 different readings too.
______________________
Craig
G2Performance
Old 10-20-2010, 03:00 PM
i have built many a engine with plastigage no problems works for me
Old 10-20-2010, 03:35 PM
Doc Speed
Neil '67 911S's Avatar
I agree with Craig. I bring my cases to an engine builder. He doesn't do Porsche engines but he's been using a bore gauge for decades on the stuff he does rebuild. Well worth the few sheckles.
- Neil
'67 911S (Ol' Ivory)
'82 Hewlett Packard 34C
Old 10-20-2010, 04:38 PM
Tadd
Good advice,....
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 10-20-2010, 05:11 PM
I will be getting my crank and newly line bored case back from Competition Engineering in the next couple of weeks. Is it everyone's consensus that I still need to, at the very least, use plastigauge to measure clearances? I know Wayne's book says it is a must, but I would like to know about real world scenarios.
Thanks,
Neil
Neil
'73 911S targa
Old 10-24-2010, 02:13 PM
tadd's Avatar
No matter who did the work, YOU should always double check.
Reputation does not completetly eliminate human error.
It is your dollars in the end....
tadd
Old 10-24-2010, 02:58 PM
