-   -   964/ 997 GT3 RS Flywheel Comparison (http://forums.pelicanparts.com/911-engine-rebuilding-forum/571034-964-997-gt3-rs-flywheel-comparison.html)
Cupcar 10-21-2010 01:47 PM
The latest GT3 RS has a lightened version of the 964 RS single mass flywheel, part number 964.102.239.81 which weighs 8.2 pounds
Up to now GT3's equipped with a single mass flywheel (Cup, Clubsport and RS) have used the same flywheel as a 964 RS, part number 964.102.239.31 which weighs 11 pounds.
This may be of interest to those who are contemplating what flywheel to use on their 964. I suspect this lighter flywheel will compound the idle issues 964's have with a light flywheel though. With Carbs or alternative FI it would be cool though.
Late development, I have been told this light flywheel ".81" part number is the same as 2005 and later 996 Cup racing cars.
http://forums.pelicanparts.com/uploa...1287693829.jpg
http://forums.pelicanparts.com/uploa...1287693850.jpg
http://forums.pelicanparts.com/uploa...1287693872.jpg
http://forums.pelicanparts.com/uploa...1287693895.jpg
http://forums.pelicanparts.com/uploa...1287693922.jpg
johnsjmc 10-21-2010 07:11 PM
If I use the 31 flywheel will a clutch from a 996 GT2/3 work on my 993
Cupcar 10-22-2010 11:28 AM
I currently have a .31 flywheel up against a 993 6 speed using a 993 Turbo/3.8 RSR plate and a 993 RS disc and it works fine. I suspect the GT2 unit would work as well.
lucittm 10-25-2010 05:48 AM
I have the turbo version of the RS single mass flywheel (12 lb), it replaced a perfectly good dual mass flywheel (30 lb) during an engine overhaul. Do you want to buy my dual mass flywheel?
Seriously. Best improvement I have made on my car. No issues at all.
Thanks,
Mark
