911SCfanatic's Avatar
Cleaning case w/ Scotchbrite
So, I'm about the re-resume my engine build, and I come across this thread:
Scotchbrite will cause your engine to blow up, etc.
and I became really, really, really frustrated. Have the rules changed again?!
For YEARS on this board people have been discussing cleaning their cases with Scotchbrite, and no one says "BOO." I think Wayne's book even talks about it, and that was written in consultation with numerous, reputable engine builders, no?. Now it's taboo. I get that there is a greater chance that something will remain in an oil passage, but I thought we all recognized that satellite assembly area clean rooms were not necessary either. Wasn't spraying out the oil passages with compressed air and carb cleaner enough (yes, I know certain types of media blasting is disasterous, but I'm not talking about that here). Cleanliness is of the utmost importance, which I get, but it seems like the rules have changed since I last checked.
I was ready to start assembly, and now I'm feeling very discouraged. Is Scotchbrite ok, or not? I've used it, so that ship has already sailed...
Bill G.
'68 911 Ossi Blue coupe
Old 11-15-2010, 12:44 PM
haycait911's Avatar
the key is the clean-up of the case afterward, with ANY cleaning method. as a last step before putting the case on the stand for final sanitizing, I like to use a pressure washer with HOT water. due to the case shape, you'll get VERY wet. but I've found this cleans out pretty much everything. using the fine jet tip in the oil passages works well. immediately after washing I blow out everything thoroughly.
FWIW I used scotchbrite on my case for the tough dirty bits, and after cleaning, I have absolutely no concerns.
Old 11-15-2010, 01:49 PM
Wer bremst verliert
JohnJL's Avatar
I've only built 3 motors but I used scotchbright on all 3 and no problems yet...
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 11-16-2010, 06:28 AM
JMHO,.....but I'll not use Scotchbrite for cleaning engine cases as its FAR too risky, even with shop-type parts cleaning machines. The effects show up later.
I use it for deglazing Nikasil cylinders.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 11-16-2010, 11:21 AM
Thank you for replying, Steve. Obviously, your opinion is valued.
I found it surprising/troubling that the concern was only mentioned in that post and nowhere else. I researched the topic pretty thoroughly, I thought. No doubt, not using Scotchbrite is the lowest risk option. However, I'm stuck with having already used it. Has there ever been a reported failure due to Scotchbrite material?
Bill G.
Old 11-17-2010, 10:37 AM
In my industry, yes. Its well documented among professional engine builders both domestic and foreign.
It shows up in damaged bearings & crankshafts, inside oil passages, and in some cases, damaged cylinder walls. The carborundum abrasive material sluffs off the pads or strips and finds its way everywhere.
Scotchbrite is an excellent product, but not for this application.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 11-17-2010, 11:11 AM
Carrerax's Avatar
Quick google found this...
Scotchbrite.....NEVER!!
1997 C4S stock...ish
1970 911T Restored Hot Rod....Sold
http://forums.pelicanparts.com/porsche-911-technical-forum/418411-here-my-new-old-project-lilly.html
Old 11-17-2010, 12:15 PM
brads911sc's Avatar
Good enough for you? They actually test the oil... and if its in there... they deny warranty replacement.
http://www.goodwrench.com/_res/pdf/EnginePdf/Engine%20General%20Installation%20Procedures.pdf
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling.
Old 11-17-2010, 01:43 PM
I'm going to get the case cleaned...
Bill G.
Old 11-17-2010, 03:25 PM
