-   -   How to compress tensioners (http://forums.pelicanparts.com/911-engine-rebuilding-forum/577505-how-compress-tensioners.html)
cmcfaul 11-28-2010 09:29 AM
I have replaced hydraulic tensioners before but have not had the issue of not being able to compress the tenisoner so that the grenade pin can be put back in. In the past I have been able to compress it by pressing it hard against a brick wall and inserting the pin. With both the left and right side they won't budge.
Is this normal? Should I put them in a vice and slowly force them to compress (slowly force the oil out of of them)?
My plan is to install them with the pins in, time the cams then pull the pins.
Chris
73 911 E
opata 11-28-2010 09:44 AM
When I rebuilt my engine I either placed them in a vice or used a big set channel lock pliers to compress them.......Hope this helps :)
Alan
Flat6pac 11-28-2010 09:50 AM
The only way I ever got them in was with a vise, slowly compressing so they bleed off without damage.
Bruce
cgarr 11-28-2010 02:00 PM
Did someone install the internal stops? This would keep you from getting the pin in.
cmcfaul 11-29-2010 08:45 AM
they compressed easily in the vice. Had an old one that I replaced and it copressed by hand (probably why it was replaced).
Thanks,
Chris
73 911 E
