-   -   how to clean zenith 40's (http://forums.pelicanparts.com/911-engine-rebuilding-forum/577618-how-clean-zenith-40s.html)
ddinham 12-07-2010 05:17 PM
Wheels,
Not real sure of your question but in the last picture you have the air correction jets installed but the emulsion tubes laying on the bench. The e tubes are installed before the air correction jets. Don't forget those "tee" shaped "plugs" under the injector nozzles too.
Dana
ddinham 12-07-2010 05:28 PM
Got off my phone and went to the desktop for better pics. You have the "plugs" installed in the air correction/emulsion tube orifices. Those go under the injector nozzles with the slotted end upwards.
Try to Google "Zenith 40" and find a breakdown of the carb. This will help you a great deal. PM me if you have more questions
Dana
Wheelsonly 12-07-2010 05:29 PM
So the t shaped nozzle's that I have next to the E tubes go under the injector ? Just so I get the lingo corret
E tubes are the long skinny thing with hole's
Air correction jets are are the treaded things that say solex on them
the shaped plug is what looks like a screw with no threads ?
Wheelsonly 12-07-2010 05:30 PM
Thank you Dana..
Wheelsonly 12-07-2010 05:44 PM
ok dana I think I got it just wanna post these to make sure sorry for all the pics I paid 1500 for my camera I figured i better use it lol..
http://img.photobucket.com/albums/v2...d/DSC02998.jpg
http://img.photobucket.com/albums/v2...d/DSC02999.jpg
http://img.photobucket.com/albums/v2...d/DSC03000.jpg
ddinham 12-07-2010 05:58 PM
By George I think you've got it!
Good work. Now you are ready for the real challenge once you get to tuning them.
Keep us posted on your journey.
Dana
Wheelsonly 12-09-2010 02:15 PM
http://img.photobucket.com/albums/v2...d/DSC03005.jpg
http://img.photobucket.com/albums/v2...d/DSC03004.jpg
http://img.photobucket.com/albums/v2...d/DSC03003.jpg
carreraplanes 12-16-2010 03:28 AM
I have a pair of Zeniths that are crying out for a strip and clean. Had heard that the accelerator pump diaphrams were NLA. Does the kit you have include the pump diaphrams:confused: Reluctant to strip them down just to find that the diaphrams fall apart but that they are unobtainium.....
James Brown 12-16-2010 07:32 AM
The Zenith rebuild kit (made in italy, for sale here) has the accelerator pump diaphragms in there. Kinda pricy but that's the only place I have seen them.
Wheelsonly 12-18-2010 02:13 PM
I belive the pelican Parts kit has them...
http://img.photobucket.com/albums/v2...d/DSC03034.jpg
http://img.photobucket.com/albums/v2...d/DSC03040.jpg
http://img.photobucket.com/albums/v2...d/DSC03038.jpg
http://img.photobucket.com/albums/v2...d/DSC03039.jpg
James Brown 12-18-2010 05:24 PM
I thought that's what I said, nice carbs, Wheelsonly
Wheelsonly 12-18-2010 05:34 PM
just out of curiosity what would these be worth...
James Brown 12-18-2010 05:42 PM
Stock, both for around $300-500
ratpiper71T 12-19-2010 09:34 AM
Wheels, nice job! Care to share your secret? what did you end up using to get them so clean? Obviously you made a satisfying project out of this. THe results speak for themselves.
Wheelsonly 12-19-2010 01:07 PM
I just use Water and pine sol with maybe 2 can cans of carb cleaner small wire brushes and some of those 3m abrasive pads to polish the brass parts..
Here is the fan I just finished I wish i would have wiped it down for the last pics..
http://img.photobucket.com/albums/v2...d/DSC03053.jpg
http://img.photobucket.com/albums/v2...d/DSC03054.jpg
http://img.photobucket.com/albums/v2...d/DSC03055.jpg
http://img.photobucket.com/albums/v2...d/DSC03057.jpg
http://img.photobucket.com/albums/v2...d/DSC03064.jpg
http://img.photobucket.com/albums/v2...d/DSC03074.jpg
http://img.photobucket.com/albums/v2...d/DSC03077.jpg
http://img.photobucket.com/albums/v2...d/DSC03086.jpg
Wheelsonly 12-20-2010 10:40 AM
I ordered so new timing chain cover gaskets I just put the old ones on for now even thought they are covered with a gallon of sealant..
http://img.photobucket.com/albums/v2...d/DSC01691.jpg
http://img.photobucket.com/albums/v2...d/DSC03090.jpg
http://img.photobucket.com/albums/v2...d/DSC03096.jpg
http://img.photobucket.com/albums/v2...d/DSC03087.jpg
http://img.photobucket.com/albums/v2...d/DSC03092.jpg
http://img.photobucket.com/albums/v2...d/DSC03101.jpg
http://img.photobucket.com/albums/v2...d/DSC03099.jpg
http://img.photobucket.com/albums/v2...d/DSC03098.jpg
Wheelsonly 12-20-2010 01:39 PM
what would an engine like this be worth ? it is a 4r-5r case with no serial numbers on it ? original internals and good leak down numbers ?
Wheelsonly 12-30-2010 01:20 PM
So I have been cleaning up other parts of the engine and was going to finish the other carb today when I noticed the other carb has a broken shaft is this something I should fix or just buy another carb ?
http://img.photobucket.com/albums/v2...d/DSC03130.jpg
http://img.photobucket.com/albums/v2...d/DSC03121.jpg
Wheelsonly 01-05-2011 01:39 PM
Anyone no where I can get this piece or a single carb ?
<object width="1280" height="745"><param name="movie" value="http://www.youtube.com/v/rY7GKCacHqw?fs=1&amp;hl=en_US"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/rY7GKCacHqw?fs=1&amp;hl=en_US" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="1280" height="745"></embed></object>
James Brown 01-05-2011 08:51 PM
I used a weber unit, could not find a zenith one. You must drill it out to make it fit.
