3.3 FOUND - Please Help me Decide.
I found an engine. I need to know if someone would pay $3000 for it??? I am going to let the seller know today. THANKS!!! It is a 3.3 tubo engine, that I would covert to an NA. It has following, and work has been done professionally;
Perfect Case, rebuilt and resealed Micro-polished crank with standard size main and rod journals New main bearings New rod bearings New intermediate shaft bearings Oil pump New chains New rails New rod nuts and bolts 6 bare cylinder heads (not installed on engine) Chain housings (not installed on engine) Chain covers powder coated yellow (not installed on engine) Upper valve covers powder coated yellow (not installed on engine) Lower valve covers modified for twin plug, also yellow (not installed on engine) Fan housing Alternator Fan 12 rocker shafts 12 rockers Both cams in perfect condition Cam housings (towers) Factory top fiberglass air shroud Not included: Sheet metal air shrouds Pistons and cylinders Exhaust Turbocharger Intercooler Intake system Engine harness, etc. Advice would be great!! Last edited by jamesjedi; 12-09-2010 at 01:40 PM.. |
Find out WHO rebuilt it.
Might be a bargain and might be a nightmare.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
Thanks for replying Steve. It was built by Al Bro#df##t. It is a 3.3, I will correct the original post. I erroneously assumed that the 91 Turbo was a 3.6, they were 3.3. That means that this engine can only be bumped up to 3.4 without splitting the case?? Or, without using thin walled cylinders.
You can make it a 3.4 without doing any machine work. Anything larger will require case modifications or thin-walled cylinders.
3.4 on 93 octane would be good for 250, in an unstressed engine??? I am really starting to like the 3.6.
I built a 3.0 that had Mahle cylinders. It went like this:
Stock crank checked and polished. Stock rods re-bushed and re-sized, balanced. Stock SC oil pump. Raceware rod bolts. Supertec studs Rebuilt '78 SC heads with race springs and retainers. JE 10.5:1 pistons. 46 Webers. Equal length headers no heat. GE60 cams. At this point I spent about $7500 Rennwerks twin plug distributor. MSD 6AL with twin coils. This set-up cost about $2,000 No dyno time yet but experts in the know say 275 hp at the crank. The seat of my pants say see'ya 350Z. This combination runs REALLY hard. It's a little pipey but I like that. ![]() Lindy Last edited by lindy 911; 12-09-2010 at 03:03 PM.. |
Can the case be rebored without splitting it?
No
Steve, what are is the real world down side of thin wall cylinders? Logic says a thinner wall will be less geometrically stable, leading to less longevity or at least more blow-by at higher temperature. What have you seen?
Lindy, that is a nice build for $7500. I am also curious about these thin wall cylinders. I think that they are called "slip on"? Perhaps is it a predictable answer.
We are quite careful about what cylinders (and sizes) we will use or sell anymore.
A BIG thanks to Steve for his contributions to this thread. THANKS.
