911 9146 engine fan housings, Possible Mismatch??
My six conversion is using an original 9146 case. I am using a 911 fan housing and 55amp Bosch Alternator. I have assembled and I'm not sure if I have a problem. See pics. Belt doesnt seem to align properly. I have 5 shims under and 1 shim on the outside. I'm wondering if the housing that I'm using may be a problem as it is from a later model car. Housing number is 930106102OR and you can see it on the second pic.
http://forums.pelicanparts.com/uploa...1292167383.jpg http://forums.pelicanparts.com/uploa...1292167390.jpg |
Thats probably the problem as the 930 housing takes the small alternator too far back giving you a mis alignment.
I have a fan housing and as you can see the back ledge that the alternator sits on is probably 3 times the thickness of the one youre using, if it were out of the car to compare. This is a 901 part, proper for a 914/6 If you want to trade, feel free, this is shelf item for quite a time, I can bead blast it for the swap. Bruce http://forums.pelicanparts.com/uploa...1292179399.jpg http://forums.pelicanparts.com/uploa...1292179455.jpg |
Housings and alternator
How much would you sell the housing for outright after blasting it?
You ll have a PM
Can I ask you to mearsure the distance from the alternator mating surface to the top of the housing lip just above that surface in the first pic you posted.? It looks a bit deep. Thanks,
I have 2 901's with the exact same part numbers, the mounting lip on one is deep like that one and the other is very shallow. I think the bcheney would have the same issue he already has with your "deep" housing.
http://forums.pelicanparts.com/uploa...1292259396.jpg http://forums.pelicanparts.com/uploa...1292259413.jpg |
95.8mm to the outer front surface from the ledge. The base of the ledge is 19mm thick.
Bruce |
I have both the deep and shallow mag fan housings available bead blasted and ready to go.
PM me for details |
PM sent
I'll trade the deep 930 housing for a 901 shallow one?
Excellent condition, glassbeeded. AND I'll pay shipping. |
| All times are GMT -8. The time now is 08:42 PM. |
