bcheney's Avatar
911 9146 engine fan housings, Possible Mismatch??
My six conversion is using an original 9146 case. I am using a 911 fan housing and 55amp Bosch Alternator. I have assembled and I'm not sure if I have a problem. See pics. Belt doesnt seem to align properly. I have 5 shims under and 1 shim on the outside. I'm wondering if the housing that I'm using may be a problem as it is from a later model car. Housing number is 930106102OR and you can see it on the second pic.
08 Cayenne V6
89 911 Targa Carrera 3.2
75 914-6 Conversion
Old 12-12-2010, 07:23 AM
Thats probably the problem as the 930 housing takes the small alternator too far back giving you a mis alignment.
I have a fan housing and as you can see the back ledge that the alternator sits on is probably 3 times the thickness of the one youre using, if it were out of the car to compare.
This is a 901 part, proper for a 914/6
If you want to trade, feel free, this is shelf item for quite a time, I can bead blast it for the swap.
Bruce
Old 12-12-2010, 10:45 AM
bcheney's Avatar
Housings and alternator
How much would you sell the housing for outright after blasting it?
08 Cayenne V6
75 914-6 Conversion
Old 12-13-2010, 04:59 AM
You ll have a PM
Old 12-13-2010, 05:21 AM
bcheney's Avatar
Can I ask you to mearsure the distance from the alternator mating surface to the top of the housing lip just above that surface in the first pic you posted.? It looks a bit deep. Thanks,
08 Cayenne V6
75 914-6 Conversion
Old 12-13-2010, 06:12 AM
Puny Bird
Mark Henry's Avatar
I have 2 901's with the exact same part numbers, the mounting lip on one is deep like that one and the other is very shallow. I think the bcheney would have the same issue he already has with your "deep" housing.
'74 Porsche 914, 3.0/6
'72 Porsche 914, 1.7, wife's summer DD
'67 Bug, 2600cc T4,'67 Bus, 2.0 T1
Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend.
Old 12-13-2010, 08:57 AM
95.8mm to the outer front surface from the ledge. The base of the ledge is 19mm thick.
Bruce
Old 12-13-2010, 01:36 PM
I have both the deep and shallow mag fan housings available bead blasted and ready to go.
PM me for details
Tom Butler
1973 RSR Clone
1970 911E
914-6 GT Recreation in Process
Old 12-13-2010, 01:44 PM
bcheney's Avatar
PM sent
08 Cayenne V6
75 914-6 Conversion
Old 12-13-2010, 07:58 PM
Porsche's Love-em Live-em
I'll trade the deep 930 housing for a 901 shallow one?
Excellent condition, glassbeeded. AND I'll pay shipping.
Old 12-19-2010, 09:16 AM
