-   -   2.4 CIS Flavored (http://forums.pelicanparts.com/911-engine-rebuilding-forum/581181-2-4-cis-flavored.html)
gumby 12-19-2010 04:30 PM
2.4 CIS Flavored
Hi, I may be looking at a top end rebuild for the very stock 2.4 CIS in my #'s matching 73.5. I am looking for info to maybe "warm her up a bit" if I can get maybe 30hp more with the same drive ability, keeping a low budget and the CIS... I know this maybe asking a bit much but....
Thanks, Ron
Flat6pac 12-20-2010 05:02 AM
About the best thing to do is put a set of CIS S cams, that wouldnt be 30 horses though. The 2.4 is very limited to keep the exterior of the engine looking stock.
Bruce
gumby 12-20-2010 05:32 AM
Thanks Bruce, Does the distributor have to re curved to match the cams?
gearheadgreg 12-20-2010 04:27 PM
Some mild port work would help, but good work is never cheap - perfect time to do it, though.
What exhaust are you currently using?
gumby 12-21-2010 05:14 AM
Stock exhaust...
The car is totally stock
The 73.5 CIS has a different spec fuel distributor and the intake tubes are smaller
In production 6 month only stuff....
Flat6pac 12-21-2010 06:18 AM
You want to keep the stock visual and there is little you can do without spending doses of money. The engine is most valuable in stock form thats why I mentioned the cams which are inexpensive.
Bruce
gumby 12-21-2010 06:54 AM
Thanks, I'll look into cams
Tom F2 12-21-2010 10:58 AM
Leave everything exactly the same, except have the crankcase opened up for 2.7 cylinders. Run Dilavar studs (don't bother with timeserts, your crankcase is still a virgin) and run the 2.7S Mahle pistons and cylinders. I did this on my old 2.4 CIS, and I loved the results. Lots of low end torque, decent gas mileage and not ridiculously expensive, at least in Porsche terms.
Is yours that Chartreuse coupe?
gumby 12-21-2010 05:30 PM
Yes...But it's Zambezi Green...paint to sample per COA
