robmog's Avatar
intermediate shaft gear ?
i got a std/std replacement crankshaft for my 2.4 rebuild.
my original intermediate shaft gear is type 1.
how can i tell if the intermediate drive gear on the new crank is also type 1?
i know i can just transplant my original, but is that necessary?
thanks
bob
1972 E pos
correction: expensive pos
someday....
"shut up and drive!"
Old 02-22-2009, 03:57 PM
It seems to me that it was stamped into the face on the gear. Also just because you have a 1 on the intermediate shaft gear doesn't mean you should have a 1 on the crank gear. I don't have my books in front of me so this is from memory. The crankcase is marked with a 1 or 0. There are allowable combinations of 1 and 0 gears to go with each crankcase. In general a 1 crankcase should have 1 gears and a 0 crankcase should have 0 gears. There are allowed mixes of the gears but I don't recall them.
-Andy
Old 02-22-2009, 09:49 PM
The intermediate shaft stamp on the gear has to match the stamping on the case next to the crank pully.
There is a list in the manual of the fit, dont fit for the im shaft
Bruce
Old 02-23-2009, 08:50 AM
robmog's Avatar
agreed, but i just noticed there are 2 different part #'s
for the crank drive gear labeled 0 and 1.
i now assume this must also be matched, but i can't see a number on mine.
bob
1972 E pos
someday....
Old 02-23-2009, 09:50 AM
I have a 3.0 crank in the garage, Ill have to look
Bruce
Old 02-24-2009, 03:10 PM
Nothing on the crank drive except the manufacture stamp
looked up on the factory pics and it shows 0 and 1 on the crank drive
Bruce
Old 02-24-2009, 04:30 PM
robmog's Avatar
i have the answer, thanks to george at ollie's!
andy had it right.
cases are either # 0 or 1
it is preferable to match your IS gear # to the case
any combination of crank gear # and IS gear # is allowed except....
you cannot put 1+1 in a 0 case
you cannot put 0+0 in a 1 case
thanks for the replies
bob
1972 E pos
someday....
Old 02-27-2009, 02:10 PM
AlfonsoR's Avatar
good info
Old 12-21-2010, 10:04 PM
Bob
The key is getting the right amount of backlash. As these gears wear, the dimensions do change and it is not unusual to get the correct amount of backlash with a set of mis-matched gears.
I'd do a trial assembly with the gear you have installed on the crank and check the backlash before changing out your crank gear.
Tom Butler
1973 RSR Clone
1970 911E - Sold but Never Forgotten
914-6 GT Clone
Old 12-22-2010, 02:28 AM
356RS's Avatar
Good information even if it's almost 2 years old.
Mark Jung
Bend, OR
MFI Werks.com
Old 12-22-2010, 07:48 AM
