Can I use pump gas?
I would like to save some money on the race weekend. Can I switch from race gas to 92 pump gas?
Calculated Compression Ratio: Chamber=67cc, Dome=22cc, Bore=90mm, Stroke=70.4, Deck=1.25mm. = 9.5:1 Compression Ratio. Twin Plugged. 500ft above sea level 28 degrees total timing DC60 cams Weber 40's - Mains 160 & AC 160, 36mm Vent. 36 intake & 32 exh. ports Thanks... |
9.5:1 with twin plug is practically over kill! 92 octane will not be a problem.
| All times are GMT -8. The time now is 04:28 PM. |
