| Registered |
				Can I use pump gas?
			I would like to save some money on the race weekend. Can I switch from race gas to 92 pump gas? Calculated Compression Ratio: Chamber=67cc, Dome=22cc, Bore=90mm, Stroke=70.4, Deck=1.25mm. = 9.5:1 Compression Ratio. Twin Plugged. 500ft above sea level 28 degrees total timing DC60 cams Weber 40's - Mains 160 & AC 160, 36mm Vent. 36 intake & 32 exh. ports Thanks...
				__________________ 1970 914-6 GT Track Car 1974 IROC Track Car 1987 911 Targa 3.2 2008 BMW X5 | ||
|  01-13-2011, 10:13 AM |
| Registered Join Date: Jan 2009 Location: Reno, NV
			9.5:1 with twin plug is practically over kill!  92 octane will not be a problem.
				__________________ Don Weaver-EBS Racing don@ebsracing.com 2006 Cayman S '86 944T '00 Boxster with EBS Racing 3.4 liter engine | ||
|  01-13-2011, 10:23 AM |
