My friends call me Phish
Cylinder Compression Issue
Old cylinders and new pistons. Cylinders 1, 2, 3 have exactly 50% less compression than cylinders 4, 5, 6. Could the valves be adjusted wrong or is the cam timing off.... or any ideas?
Old 01-13-2011, 10:44 PM
Did you open your throttles to the other side>?
Old 01-14-2011, 09:42 AM
yea they are open.
#1 85psi
#2 57psi
#3 57psi
#4 115psi
#5 118psi
#6 116psi
Haven't looked at the valves yet, so I am hoping that is the issue
Old 01-14-2011, 11:26 AM
double checked the throttles....closed.
that solved the problem, thx
Old 01-14-2011, 09:35 PM
