mfi injector washer question
a simple question:
my engine rebuild gasket set has 2 different copper washers that could be used to seat the injectors on the head. plain copper vs. crush copper. am i safe in assuming the crush type are correct? thanks, bob
bob 1972 E pos correction: expensive pos someday.... "shut up and drive!" |
seals
For the injector to cyl. head the solid copper seals are used.
Mike Bruns
The two most useless things to a driver are the braking distance behind you and nine-tenths of a second ago. |
