Rennsport 2.5l FIA Group 4 Motor Completed....
Its done. Even with the restrictions imposed by the 1971 FIA Group4 rules, its making over 260HP and 200 lb-ft at the crank with mild cams (for circuit rallying) and the restriction of the 2.5 litre 10.3:1 Mahle P&Cs. Good enough for its vintage track and rally circuit duties.
Early dyno pull is on You Tube:
YouTube - 1972 vintage Porsche 911 FIA Group 4 engine dyno test
The real test will be on the track.
Thank you Steve Weiner.
Old 01-21-2011, 06:43 PM
brads911sc's Avatar
Wow. Nice. Congrats!
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling.
Old 01-21-2011, 07:07 PM
agrimmitt's Avatar
Location: Mesa Oaks, CA: Zone 8>PCASB/PCACC/POC/NASA member
Send a message via Skype™ to agrimmitt
Thumbs up
Very nice, wish I still have mine from the late 70's!!!! Much fun and big smiles are ahead for you!!!
art
Old 01-21-2011, 07:17 PM
Impressive figures. Did Steve build it?
Old 01-22-2011, 01:58 AM
Love the reversion from the carbs.
Very nice!
Tom Butler
1973 RSR Clone
1970 911E - Sold but Never Forgotten
914-6 GT Clone
Old 01-22-2011, 02:15 AM
304065's Avatar
W O W
Is that Series900 fiberglass engine tin?
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 01-22-2011, 05:23 AM
Yes - this engine was built by Steve Weiner and fuel reversion is pretty evident above the intakes in the video! That was an early run and Steve made a few changes to the setup including jetting and header sizing. In the end we sacrificed some top-end power (it was capable of pulling a higher number) but gained more midrange pull and improved tractability which we needed as part of the mixed-use specification for the build - which means that it can't be an all-out track car. As it stands now we want to keep this below 8,000 RPM for engine durability and max power comes at around 7,800 RPM. We will run this configuration in the car first and see how it goes. Its being used with a short stack gear set to limit top speed at 8,000 RPM to approximately 230 km/hr. The rest of the car is being built by Markus Blaszak to 1971 FIA Group 4 specifications.
Old 01-22-2011, 07:08 AM
MBEngineering's Avatar
HI 72group4
not wanting to put a spanner in the hard work on the engine build, but you may not pass FIA inspection for 1971 with pressure tensioners, just not period then, having to change all my rally/race engines over hear that are running to FIA historic rallying and racing.
regards mike
Old 01-23-2011, 05:15 AM
HI 72group4
is it a 2.2 or 2.4 crankcase used as basis ?
Is it a short or long crankshaft ?
What type of carburators do you use ?
thanks
Best regards
Manu
Old 01-27-2011, 09:50 AM
Originally Posted by manu72S View Post
HI 72group4
thanks
Best regards
Manu
I may be able to answer your questions.
Thats a 7R case.
The crankshaft is a custom configuration
46mm Webers
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 01-27-2011, 09:58 AM
Wer bremst verliert
JohnJL's Avatar
With 200% respect to the workmanship and reputation, does a custom crankshaft meet 1971 FIA Group4 rules?
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 01-27-2011, 06:01 PM
Yessir,..its the same stroke.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 01-27-2011, 07:45 PM
MRD MRD is offline
MRD's Avatar
That seems pretty well built Love that sound.....
68 S coupe
71 T targa
Old 01-28-2011, 04:27 AM
