-   -   Thoughts on these P&C measurements (http://forums.pelicanparts.com/911-engine-rebuilding-forum/588745-thoughts-these-p-c-measurements.html)
jwasbury 01-30-2011 07:47 AM
Helping a fellow pelican with their EFI turbo engine as documented in this thread:
http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/585378-engine-drop.html
I realize after further study that I made some of my measurements in the incorrect locations, however I think they are probably still useful and indicative. I believe that the P&Cs are all junk.
#6, no need to measure here...we know this is junk
http://asbury.smugmug.com/By-Land/My...99_wzpFE-L.jpg
#1, I did measure this one, but visual inpection indicates a problem. What causes this wear? Heat? Interesting that the cylinder doesn't look all that bad (Nikasil plating is that tough?).
http://asbury.smugmug.com/By-Land/My...59_wGUHB-L.jpg
Other side of #1. It does look like the crown was melting/beginning to deform here too, but didn't get as far as #6 (my first photo)
http://asbury.smugmug.com/By-Land/My...57_jjuyE-L.jpg
Here's a chart of measurements. For reference, "A" axis is parallel with wristpin, "B" is perpendicular to wristpin.
http://forums.pelicanparts.com/uploa...1296402068.jpg
Whadd'ya think?
Steve@Rennsport 01-30-2011 09:38 AM
Thats all damage from detonation.
tom1394racing 01-31-2011 02:43 AM
A few of the cylinders look to be out of round. The ovality limit is 0.04mm.
This is not unusual with the 1/2 finned cylinders.
jwasbury 01-31-2011 06:43 AM
Agreed on them being outside of spec for ovality...
unfortunately, these are not the 1/2 finned 3.3 jugs...they are 3.4L Mahle motorsport "yellowbird" P&Cs ($$$$$$$)
