-   -   A Shadetree's 930 Rebuild (http://forums.pelicanparts.com/911-engine-rebuilding-forum/589915-shadetrees-930-rebuild.html)
Alan L 02-28-2011 10:57 PM
OK, the situation gets weirder.
In spite of what Tom has suggested, I get very squeemish about using so much force on an unknown problem. There is a chance of causing more damage.
Is there any way, with the pistons you have out of looking into the case with a torch and mirror. If it is locking the crank up, you would hope it is obvious - not too many options in there.
Alan
Kemo 03-01-2011 07:22 AM
is there anyway to remove a link from the chains and get them out of there completely? That would certainly solve any concerns about chains binding.
Also, are the pistons re-usable? If not, here is a drastic and probably the worst idea ever. break out the hole saw and cut a nice hole thru the crown of the piston...then you can use a sawsall to cut the wrist pin on each side and pull whats left of of the piston out.
anxious to see how this all plays out.
tom1394racing 03-01-2011 08:35 AM
Rob
Before you cut up any potentially reusable parts, try my suggestion. If the crank does not turn, try a wood block and hammer on the nose of the crank to free it up.
jpnovak 03-01-2011 09:09 AM
Looking at the picture of a partial short block i see that your chain has dropped all the way into the case. This is likely what is locking the crank in place.
Even though you have pulled them out of the case they are probably not pulled ALL THE WAY out and tight against the crank timing sprocket.
I suspect the crank will rock back and forth just a few degrees allowing brief relief in chain tension. You are going to have to work carefully to free the chain, make sure it stays tight against the crank pulley until you get the case split.
Alan L 03-01-2011 10:31 AM
I agree with Jamie - even with the chains looped outside the timing case, if they dropped in before, they can still be bound up. You need to be able to see the sprocket teeth clearly around the crank from both sides of the timing cases. If this is so, please let us know and we can eliminate this possibilty. believe me I have been stuck at this point before also, and was tempted to lean heavier on the crank pulley. All I would have done is munched the chains and block.
Unless the chains have been replaced with the aftermarket version, there is no joining link - they are continuous.
If they are jammed in the bottom of the case, they can be freed.
Alan
930LDR 03-05-2011 08:45 AM
Thanks guys for all the suggestions. Just got back into town and will be working on this later today.
I'll give the chains a thorough inspection one last time before proceeding but realize that the crank was locked up before the tear down even began so odds are we're dealing with something within the case. Spent some time on the phone with my mechanic in Chicago yesterday and he's thinking I may have friction welded one of the rods to the crank. Looking at the number 2 piston this morning I noticed it doesn't have the same back and forth play relative to the crank as the others so this may be the issue.
His suggestion was to put the flywheel back on, bolt a long piece of angle iron to it and use some force to break that rod free. May try this in conjunction with the earlier suggestion to turn the motor 90 degrees so that the case seal is perpendicular to the floor.
If this doesn't do it I may be looking at drilling through a couple of pitions (fortunately I was likely going to need a new set anyways.
930LDR 03-05-2011 08:48 AM
Tom -
Can you elaborate a bit on he use of the wood block? Is the suggestion to give it a good whack as though you were trying to push it through the case?
Regards
PFM 03-05-2011 09:55 AM
930LDR,
This is just not fun. If the motor locked up at idle I doubt the rod micro welded to the crank. If the number 2 rod will not rock on the crank clearly that is a problem. Something in the oil pump will make it all feel locked up but you should feel a little play in the crank. Does the crank move at all in the inline direction, nose to flywheel, if it does skip the wood suggestion the crank is not frozen in at the mains.
If you feel reversing the motor will get you some movement in the crank reinstall the flywheel it will allow you to rotate the motor in reverse rotation, to possibly un bind something.
Good luck and keep us posted.
Alan L 03-05-2011 12:08 PM
What a mystery. But as I understand it, you were puttering around in the backyard when it stalled. If you were giving it death on a track I could understand the bearings getting tight. It must have had a main bearing starving for oil if this is the case. Are you able to squirt any lubricant - WD40 type, on a the plastic tube extension nozzle, down around the suspect rod bearing. Then see if it frees up. If in fact it is a tight bearing, you will do no more harm by levering the engine another 90 deg. The bearing is already toast and the crank will stand the force. But until you know what you are forcing I would suggest more investigation before applying brute force. With what room you have to move, the rod should be able to rock back and forth freely. But if it is locking the engine, you will not be able to move it AT ALL. If you can move it, then you can rotate the crank against it.
Can you get a torch and small inspection mirror down thru the gaps into the case?
Alan
Flat6pac 03-05-2011 01:22 PM
Cut the chain and pull it through, remove a possibility. Put the flywhee back on, put studs in the flywheel and a long bar and turn it backward to relieve the chain if thats the problem.
Bruce
CaptainCalf 03-05-2011 02:06 PM
Good stuff count me in and good luck freeing that crank 930LDR!
930LDR 03-05-2011 04:09 PM
There is enough play in the crank that it can be rocke back and forth until that number 2 piston hits up along the case... then I'm stuck.
930LDR 03-05-2011 04:11 PM
At this point I'm worried about putting too much force against the crank as I don't want the number 2 piston to damage the section of case that its coming into contact with.
Flat6pac 03-05-2011 04:28 PM
If you are supporting the #2 piston square there should be no interference with the case. Only with the piston rocking and not square can it hit the case.
Bruce
930LDR 03-05-2011 04:40 PM
Understood. Whats the suggestion on holding it square while trying to rotate the crank and get it to break free?
PFM 03-05-2011 05:02 PM
930LDR,
Remove the rings from the piston and slide a cylinder over it. The cylinder will keep it from getting into trouble. If the rock stops with the cylinder in place the rod is locked to the crank.
tom1394racing 03-05-2011 06:29 PM
Sounds like the rod for #2 piston is "welded" to the crank journal.
PFM 03-05-2011 09:04 PM
Tom,
Do you find it a bit odd that it welded at idle? Just asking.
930LDR 03-05-2011 10:41 PM
Problem SOLVED!
The issue was the number 2 piston. Bearing broke and spun around on itself jamming the rod. The solution was to drill through the piston so that I could get a 6" extension and 11mm 12-pt socket down to the rod nuts. Once those were off I was able to pull the piston and rod as one piece and this freed up the crank. Was able to get the remainder of the pistons out and split the case without issue.
Thanks for all the suggestions guys. BTW... I was suprised at how soft the piston actually was... standard 3/8th drill bit and a cordless drill cut right through the damn thing... sure wasn't pretty though. surface of the piston is so chewed up because I tried to use a 3" hole saw which just ended up jumping all over the place.
https://lh3.googleusercontent.com/-T...00/bearing.JPG
village idiot 03-05-2011 11:14 PM
Wow, that must have made you queasy drilling into the piston like that:eek:
PFM 03-06-2011 12:16 AM
930LDR,
Nice work, the spun bearing makes sense at idle, my guess is oil pressure was a bit low at idle and got it. I would replace that rod regardless to how it checks out. How is the crank?
Looks like you will need a piston now for sure.
350HP930 03-06-2011 08:16 AM
Good work Rob, glad you managed to get in there.
930LDR 03-06-2011 12:26 PM
What... don't think that can be cleaned up? Fortunately this was one of the pistons that had damage on the surface anyways. I may end up replacing the whole set and going 3.4L since there are a couple more less than perfect pistons in the lot.
James Brown 03-06-2011 01:39 PM
Keep the piston and rod and mount it on a wooden base and hang it in your garage as a subtle reminder of the cost of speed!
930LDR 03-06-2011 09:57 PM
As I'm looking at P&C options... any thoughts or recommendations on staying 3.3L or going 3.4L (or 3.5L)?
CaptainCalf 03-07-2011 04:52 AM
I read once that a good reason to go to 3.4L jugs & slugs is cuz the aftermarket cylinders run cooler due to a different fin arrangement then the OEMs, but I don't have 1st hand knowledge if it's true or not. Also, if you go larger then 3.4L then you have to bore out the case some to make room for the larger slugs.
jpnovak 03-07-2011 05:56 AM
Great job getting that piston off. I am sorry I missed the point that the engine seized. I thought it was free and then was stuck after you put the top-end off.
Can you cut the remainder of that piston in half so we can get a measurement on the crown thickness?
This is important for those who want to cut valve pockets in stock pistons.
Thanks.
Alan L 03-14-2011 01:26 AM
Well, I stand informed - a spun bearing under minimal load. Does that mean we should thrash them more regular?
I guess you had no other option. I cant see what else you could do, altho there have been many spun 930 bearings before. I guess it depends where the crank stopped and you drew the short straw.
Alan
930LDR 06-14-2011 08:01 AM
Sorry... been off for a while on business...
Jamie - Don't mind cutting the piston and taking some measurements for you.
Alan - Definitely drew the short straw although a couple of the pistons had some detonation damage (including this one) so it would have needed to be replaced anyways...
