-   -   Engine plug? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/589992-engine-plug.html)
JJ 911SC 02-05-2011 07:35 PM
Engine plug?
Any idea what that is (look like a plug with a date code) and why its there(right side lower casing)?
http://forums.pelicanparts.com/uploa...1296963185.jpg
TibetanT 02-05-2011 08:32 PM
Is this on the engine case? should be one of these on each side of engine case, left and right side.
Is this a 3.0L or a 3.2L?
If 3.2L engine, best guess...the 28th week of 1985 ...but I am no expert.
JJ 911SC 02-06-2011 04:41 AM
Hi Ed
I guess I could have supply more info...
86, 3.2 Engine, so the 28th week in 85 does make sense
On the passenger side of the Crankcase (930 101 104 5R)
Nothing on the other side (930 101 103 6R)
What is (was) the purpose for it?
Cheers
JJ
Flieger 02-06-2011 11:00 AM
The purpose is just to keep track of production. If something does not meet QC specs, they can identify when and what die the problem occurred, then go and fix it and then inspect the ones that were made after that more closely. It also is nice to know when the part was made, just like it is nice to know when your car was made, even if an 83 is basically the same as a 78 or an 85. Fatigue cracking, for one, though this only seen in highly stressed engines.
JJ 911SC 02-06-2011 12:52 PM
Flieger 02-06-2011 05:48 PM
By the way, just to make sure you know, it is an imprint from the mold, not a "plug".
JJ 911SC 02-06-2011 06:30 PM
I called it a plug because it resemble to wooden plug I made for a Windsor chair.
I do QA check on 1st Level casting for submarine valve and the likes but we use a different marking systems.
What trough me off is the "look" of the bar between the Year and the Week as it does not really match its surrounding and being paranoid about finding bad news :eek::D:eek:
http://forums.pelicanparts.com/uploa...1297045712.jpg
