Rear end of 7R case?
This is the first 7R case I came across and I wonder if this is how they normally look at the rear end? The earlier cases I have do not have the same amount of mounting points for the cam chain guides?
Thank you for your time! http://forums.pelicanparts.com/uploa...1297182253.jpg |
What is the engine #? 911/??
I can not find any type or serial number unfortunately.
Interesting, looks like a 3.0 case but it's mag? right.
I have come across cases with multiple bosses, but they have never been machined. Your case appears to have been machined and plugs installed. I am not sure what the purpose of the extra bosses were for.
Ok, I have never seen or thought about those bosses earlier. All of the holes are machined/threaded and they all seem to have been used so I a bit curious if somebody know for what they could possibly been for?
If there are no numbers then maybe it was a late 7R replacement case that, by default, is fully machined. I have not seen any pictures of an application that required the relocated guides. The 4 cam engines used the traditional ramp locations....
| All times are GMT -8. The time now is 01:29 PM. |
