-   -   ACTUAL Compression Ratio on 964/993 3.6 (http://forums.pelicanparts.com/911-engine-rebuilding-forum/590713-actual-compression-ratio-964-993-3-6-a.html)
YTNUKLR 02-09-2011 11:29 AM
What is the (carefully measured) compression ratio on a 964/993 3.6L? Books quote 11.3:1 but I have heard it is actually lower...
Thank you,
Scott
304065 02-09-2011 02:45 PM
http://forums.pelicanparts.com/911-engine-rebuilding-forum/168555-964-engine-rebuild-11-3-1-compression.html
Factory cup motors with a factory seal, when opened, show interesting things. . . :)
Steve@Rennsport 02-09-2011 08:50 PM
Thank you,
Scott
Between 10.6-10.8:1.
YTNUKLR 02-10-2011 09:57 AM
Thanks!
-Scott
