Crankshafts 2.4, 2.7 and 3.0
After reading a post that mentioned the 2.4, 2.7 and 3.0 crankshafts are all the same, I was hoping to see if it anyone could confirm this? Also, is there a difference between Euro and USA cranks? I ask this because I will need a std/std.
As always...THANKS! |
They are not the same.
Tell it like it is or don't tell it at all. |
Thanks for the reply.
James |
The 2.4, 2.7 .and 3.0 crank and rods are all the same for the 76 and 77 run of engines including the 3.0 Carrera of 76/77.
The 3.0 changed in 1978 to a 9 bolt flywheel and a different thickness rod. Bruce |
Got it. Thanks. No now it makes sense.
James |
