piston pin really tight
I am rebuilding my 73.5 CIS 911 Targa and the OEM piston pins are not happy going into the OEM pistons. The pistons were cleaned at a machine shop and the pins are not happy trying to insert back into the pistons. Should I have to knock the pins in with some force with my plastic hammer or should they simply slide in?
Old 09-12-2011, 09:03 AM
CaptainCalf's Avatar
You may want to check the edges of the pin bores in the pistons for burrs & check for any dirt/grit left in the pin bores from the machine shop.
Also, just in case you didn't try this already, put some oil or lube on the pins and in the pin holes to help them slid in with a little tapping with a rubber mallet.
FS 1987 930 DTAFast EFI w/Electronic Dash, 17x9x11" Lindsey Racing Fuchs, Andial 8.39 R&P, C2 Intake, SuperCup Cams, Flame Ringed Heads & Cylinders, TurboKraft Full Bay Intercooler, RearlyL8 Twin Scroll Headers, Big Bullseye Twin Scroll Turbo...SOLD
1999 Harley Davidson Custom 1250 Hardtail Bobber..SOLD
2014 BMW X6M, 2012 BMW 128i, 2014 GMC Sierra, 2015 Cobia 237 Center Console 300hp Yamaha
Old 09-12-2011, 09:23 AM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
Keep the pins in the fridge overnight...they will slide in easier.
Bob
Bob Hutson
Old 09-12-2011, 10:20 AM
Bob has the right idea, I heat the piston crowns with a propane torch. You only need to get the pistons hot enough to slip the pins in.
-Andy
Old 09-12-2011, 12:32 PM
