Hbrand
hbrand's Avatar
Camshaft identification
I recently bought a 1972 911E Coupe, with camshafts installed with "SE" markings in the front.
It is an MFI engine, 1973, unknown pistons-cylinders. The valve overlap is adjusted to 50, there are solid chain tensioners installed.
Please identify those cams.
Thanks, Harold
Cheers
1982 Porsche 911SC Euro
1969 Mercedes 280SL
1956 Austin Healey 3x
Old 02-26-2011, 05:35 AM
bavaria911's Avatar
Harold,
I tore down my 2.4 E (1973) motor to find it has 2.2S P&Cs and the S/SE cams.
A few pelicans told me both cams were 911S and the SE was for both the S and E motor.
Here are my two:
I still have the 2.4T MFI system in the basement.... Hope the Florida weather is better than Marylands.
Scott
Bavaria911
1970 911T w/ 2.4S
1971 911T Targa w/ 2.2
RG Member # 818
Old 02-26-2011, 09:07 PM
Hbrand
hbrand's Avatar
Cams
Scott, those are the same I have.
so the overlap is OK, the problem wit 2000-3000 RPM missing is then somewhere else.
The MFI number is 13= 911T but it lucks rebuild. Maybe to S specs too. I did one day of adjustments, it is better now but still there.
Thanks, Harold
Cheers
1969 Mercedes 280SL
Old 02-27-2011, 05:49 AM
