3.6 rebuild research--which rods/pistons can I use with a GT3 Crank?
Trying to confirm what I can use here. Anyone update to the GT3 crank and what did you use? Thanks
Others have custom Pauter's w/ custom pistons made I'd suggest talking one on one to a knowledgeable builder. These sorts of things aren't off the shelf, bolt em up projects |
Thanks Bill. I may need a new crank for my early 964 and have read the gt3 crank could possibly be an upgrade worth pursuing but didn't know if factory rods or pistons could be used. I'm in the initial research stage. This is for my street/track 911.
You really need to talk to someone that has built these motors, Henry Schmidt, Steve Weiner, Geoffrey Ring, Colin Beltin, Jerry Woods etc |
There are two ways to go about using a GT3 crank.
You will need of the shelf 3.0 liter rods and pistons with an altered pin height. or custom rods (3.0 liter big end 127mm center/center) and stock type pistons The snout will require 4mm machined off and the dowel pin enlarged Pully from an earlier engine or a custom pulley |
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 sez use GEN II GT3 Pankl titanium rods. 3.0 big end and 130 mm center to center and Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 The GT3 crank is design to use a replica of a 3.0 rod 127.8mm center to center, 22 mm wrist pin, big end width 21.7mm, and big end diameter of 56.00mm. If you really want to use those pistons and Pauter rods the c to c length should be 127mm with a wrist pin of 23mm. You might also try rebushing a Pankls to 23 mm and dimensioning the engine (shim the barrels and chain boxes) to suit the longer rods. It's done all the time. Nothing new here. In discussions w/ Geoffrey Ring I got the impression that he is using stock 130mm GT3 rods w/ custom pistons, but I could be wrong |
Chris at Turbokraft used B&B rods with GT3 crank in this build
http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/537664-2010-efi-hot-rod-odyssey-4.html |
We are sourcing R+R Rods from Charles at LN now for our GT3 Crank build. Using 131mm rods with our JE pistons from our CMW stroke race engine. Gt3 Crank is much more cost effective than anything else we found.
We looked at Carrillo, Cunningham, Arrow, Pankl, and Pauter prior to leaning towards R+R. We have not pulled the trigger on the deal, so we would like to hear the pros and cons from the forum. Andrew |
| All times are GMT -8. The time now is 11:19 AM. |
