-   -   Capacity increase question (http://forums.pelicanparts.com/911-engine-rebuilding-forum/601457-capacity-increase-question.html)
911TT33 04-06-2011 02:44 PM
Hi,
If one were to use a 964 crank with 98mm P&C's in a 3.2 motor, what would be the resulting capacity of the motor? 3.5L all up?
What about 100mm P&C's with the same configuration?
BURN-BROS 04-06-2011 03:26 PM
98mm will be a 3.5
100mm is a 3.6
911TT33 04-06-2011 05:39 PM
Thanks for confirming ;)
Two Rivers 04-18-2011 08:01 AM
BoreXBoreXStrokeX785X6 = Displacement Of a six cylinder engine.
Easy-est way I found to calculate displacement.
Substitute the six for any number.
brp914 04-19-2011 07:53 PM
What are the implications of using the 3.6 crank?
Can you use the 3.2 flywheel?
Do you have to space out the cylinders? Chainboxes?
Would the 98 mm piston/cylinder kit be the same as that used in taking a 3.2 to 3.4?
Can a stock 3.2 motronic accommodate this change?
Can you use the 3.2 distributor?
Anything else?
Sorry for the semi-hijack.
