Capacity increase question
Hi,
If one were to use a 964 crank with 98mm P&C's in a 3.2 motor, what would be the resulting capacity of the motor? 3.5L all up?
What about 100mm P&C's with the same configuration?
Old 04-06-2011, 02:44 PM
BURN-BROS's Avatar
98mm will be a 3.5
100mm is a 3.6
Aaron. F.S. 1965 Solex engine w carbs/cleaner
Burnham Performance
https://www.instagram.com/burnhamperformance/
Old 04-06-2011, 03:26 PM
Thanks for confirming
Old 04-06-2011, 05:39 PM
Two Rivers's Avatar
BoreXBoreXStrokeX785X6 = Displacement Of a six cylinder engine.
Easy-est way I found to calculate displacement.
Substitute the six for any number.
Old 04-18-2011, 08:01 AM
What are the implications of using the 3.6 crank?
Can you use the 3.2 flywheel?
Do you have to space out the cylinders? Chainboxes?
Would the 98 mm piston/cylinder kit be the same as that used in taking a 3.2 to 3.4?
Can a stock 3.2 motronic accommodate this change?
Can you use the 3.2 distributor?
Anything else?
Sorry for the semi-hijack.
Old 04-19-2011, 07:53 PM
