Chain fence eating turbo
Question Cylinder head to cylinder/barrel fit?
Does the head fit snugly to the cylinder/barrel or is there some looseness where the head can shift around slightly?
3.2L BTW.
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel
Old 04-14-2011, 07:18 AM
abit off center
cgarr's Avatar
Not snug, they do shift around a slight bit.
______________________
Craig
G2Performance
Old 04-14-2011, 07:55 AM
Thanks Craig! I thought I was hosed!
Great work on my heads!
Old 04-14-2011, 08:21 AM
So, should I have the head nuts loose, install the cam housing/tower over the studs and dowels on the heads, and then snug the head nuts down before torquing?
When I was messing around and I hadn't torqued the heads down (just snug), I noticed the cam towers wouldn't easily slide over the studs. Being the heads shifted around somewhat, I figured they may not seat exactly in the exact spot needed after torquing making the towers a struggle to slde on.
Am I missing something?
Old 04-14-2011, 11:49 AM
abit off center
cgarr's Avatar
Seal, bolt and torque up the heads to the cam towers then install them on the cylinders as a set and torque them down.
Work the complete set down slowly as you will have the oil return tubes in there. Go around with 5# increases or so.
Craig
G2Performance
Old 04-14-2011, 11:56 AM
Ah yes, I totally forgot about that method.
Thanks again!
One more question:
All my heads have the temp sensor hole/boss. I thought only 1 (#3 cylinder) out of the set does?
Old 04-14-2011, 12:19 PM
abit off center
cgarr's Avatar
3.2 heads have them in all heads so you can put any head on any cylinder but I did notice that one of your heads temp port did have a plug in it for some reason...
I would guess its easier to just manufacture them all the same?
Craig
G2Performance
Old 04-14-2011, 12:43 PM
Ah, I see. I'm good to go then.
Thanks!
Old 04-14-2011, 12:47 PM
