-   -   79 3.0 top end and reseal (http://forums.pelicanparts.com/911-engine-rebuilding-forum/601630-79-3-0-top-end-reseal.html)
Flat6pac 04-07-2011 01:48 PM
This motor sat for several years in the car but I had never seen an SC so rusty. The rust carried over to the sheet metal, exhaust, and cylinder dividers.
I m not able to get the fan apart from the alternator, heat, Zep on any pressure I can exert trying not to destroy anything.
Center case was never opened, the white case seals are from before my time in Porsche, 30 years building and I never built with them.
Miked out standard on the mains, cleaned the case and replaced everything where it came from, fresh seals, and intermediate shaft bearings.
This 3.0 has replacement 993 dilivars only on the bottom row
Bruce
http://forums.pelicanparts.com/uploa...1302208595.jpg
http://forums.pelicanparts.com/uploa...1302208804.jpg
http://forums.pelicanparts.com/uploa...1302209004.jpg
http://forums.pelicanparts.com/uploa...1302209072.jpg
ninesixfour 04-11-2011 04:31 PM
So you just split it to measure everything and you only replace what's needed? Just looking at all that rust makes cringe at the thought of trying to tear it down.
Flat6pac 04-11-2011 06:11 PM
The rust has all been thrown away, exhaust, cylinder dividers, sheetmetal, etc. There is no use trying to clean rust.
Bruce
ninesixfour 04-12-2011 05:28 PM
Are the cylinder dividers called "baffle plates" in the parts catalog? I don't see the engine tin either.
Flat6pac 04-12-2011 05:34 PM
Yes, baffle plates and the engine tin is called cover.
Bruce
