-   -   Is 2.4 distributor ok for 2.7 with Webers? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/602637-2-4-distributor-ok-2-7-webers.html)
marlinaness 04-12-2011 08:02 PM
Just installed Webers on a 2.7 (from CIS). I understand I have to have the distributor recurved or it won't work right. Will a 2.4 distributor be ok? What are the issues with the 2.7 CIS distributor? Would 2.2T cams be an ok upgrade on the CIS cams to make this all work better?
thanks in advance
best regards
Marlin
Flat6pac 04-13-2011 06:19 PM
The distributor will do fine. Not much difference between applications except maybe the Carrera mechanical injection distributor. More is based on the cam action.
Bruce
Eagledriver 04-19-2011 10:46 AM
2.4 dizzy works great with carbs on a 2.7 engine. 911T cams will not work with CIS pistons
marlinaness 04-20-2011 08:42 PM
thank you both very much. the current distributor did not seem to work correctly. will try a 2.4 dizzy this weekend. Next step if this doesn't work will be to send the dizzy to Barry Hershon to be rebuilt.
thanks
Marlin
