Motor Rebuild Definition
Hey Guy's,
I friend and I are having a difference of opinion on the definition of a motor rebuild. I want to hear from you! What constitutes a motor rebuild in your opinion?
If you were buying a rebuilt motor what would you expect? All opinions appreciated.
Dean
Old 04-21-2011, 05:54 PM
OldTee's Avatar
While a standard definition would be nice, it is up to the salesman and how he uses the words. A good salesman will stretch the truth and call it how he will.
Make your own definition and insist on seeing the records.
Try using words like "split the case", "refinish the crank", "regrind the cams", "replace the cylinders with new" for searching out a true major overhaul.
911 Engines needing a rebuild or overhaul vary but a rule I use is:
Over 100K miles - do the top end. Unless there is a reason the low end should be ok if oil was changed regularly.
Over 150K miles - split the case and do it all.
FWIW
Old Tee
all 911s sold
Old 04-22-2011, 04:57 AM
CaptainCalf's Avatar
+1 Oldtree, I think it all comes down to case splitting or not.
If it were me I wouldn't call it a rebuild w/o splitting the cases in order to check all tolerances and replacing mains brgs, rod brg, rod bolts & head bolts.
However, it's all relative and that's just my 2 cents,
RC
FS 1987 930 DTAFast EFI w/Electronic Dash, 17x9x11" Lindsey Racing Fuchs, Andial 8.39 R&P, C2 Intake, SuperCup Cams, Flame Ringed Heads & Cylinders, TurboKraft Full Bay Intercooler, RearlyL8 Twin Scroll Headers, Big Bullseye Twin Scroll Turbo...SOLD
1999 Harley Davidson Custom 1250 Hardtail Bobber..SOLD
2014 BMW X6M, 2012 BMW 128i, 2014 GMC Sierra, 2015 Cobia 237 Center Console 300hp Yamaha
Old 04-22-2011, 06:11 AM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
Just beware of the old "2 tool" rebuild (steam cleaner..and spray can).
I have seen many bargains turn out to be like this.
I even saw one that was cleaned and sprayed...but the old black oil was still in it...along with the old filter (which had been wiped clean).
There are people out there that will cheat you if you let them.
MM comes to mind....LOL
Bob
Bob Hutson
Old 04-22-2011, 11:26 PM
Dean
I would expect to see the actual invoice including a list of all the parts that were replaced, the work that was actually performed, the number of miles since the rebuild, compression and leakdown numbers, and the name and contact information of the shop that did the work.
Gone
92 C2
82 Euro SC race car
993 C4S 3.8
84 Euro Carrera
Old 04-23-2011, 05:14 AM
