Will a 0 231 159 001 distributor work in a 1970 911T?
I am looking to replace my 911T's Marelli distributor with a bosch one. Will this one work? Or do I need to have it recurved?
1966-67 Porsche 911 Bosch Distributor 0 231 159 001 | eBay
Old 06-01-2011, 01:27 PM
It ll work and with a T there is no need for any other work.
Bruce
Old 06-01-2011, 01:35 PM
304065's Avatar
I disagree, that's an old cast iron distributor designed with an advance curve for solex engines. The T curve is different, not by a ton, but different nonetheless. Also that will stick out like a sore thumb in the engine compartment- one would expect to see an aluminum body distributor, not a cast iron one from the 356 days (like our SWBs)
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 06-01-2011, 03:21 PM
deathpunk dan's Avatar
Look for one of these:
0 231 159 008 (oem 2.2t)
0 231 159 006 (2.2E)
Alternatively, you could use a 2.4/2.7 dizzy but have the shaft machined to fit your car's case. Just remove the vac advance. At least, this is what I have been told.
My car has an 006. It works fine. The 007 S curve is too radical.
Sepia brown 1971 911T.
Old 06-01-2011, 05:14 PM
