-   -   Piston Pin too short ? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/612332-piston-pin-too-short.html)
Rich75 06-05-2011 01:34 AM
Hi,
I want to assemble new JE pistons to my 911 2,4T engine.
If the piston pin is installed, it can be pushed ~4mm from one side to the other.
Is this all right ?
The old Mahle-pin is 4mm longer, would fit perfect.
I build up many motors, but never seen so much side-move on a piston pin
Got I the wrong pins ? ( They come seperatly packed, not stuck in the pistons :confused:)
regards,
Rich
MBruns 06-05-2011 08:46 AM
pins
They are the wrong pins, Je's pins have a chamfer on the OD of each end that when installed they fit closely with the circlip, that keeps the hammer effect of the pin working on the clip groove. I have seen clip grooves more than double the width with a pin just a bit short.
Mike Bruns JBRacing.com
Rich75 06-05-2011 09:23 AM
Thanks for answer,
this is my opinion too.
So I have to contact my dealer...
THX,
Rich
