Piston Pin too short ?
Hi,
I want to assemble new JE pistons to my 911 2,4T engine. If the piston pin is installed, it can be pushed ~4mm from one side to the other. Is this all right ? The old Mahle-pin is 4mm longer, would fit perfect. I build up many motors, but never seen so much side-move on a piston pin Got I the wrong pins ? ( They come seperatly packed, not stuck in the pistons )regards, Rich |
pins
They are the wrong pins, Je's pins have a chamfer on the OD of each end that when installed they fit closely with the circlip, that keeps the hammer effect of the pin working on the clip groove. I have seen clip grooves more than double the width with a pin just a bit short.
Mike Bruns JBRacing.com
The two most useless things to a driver are the braking distance behind you and nine-tenths of a second ago. |
Thanks for answer,
this is my opinion too. So I have to contact my dealer... THX, Rich |
