-   -   Identifying a 911 engine (http://forums.pelicanparts.com/911-engine-rebuilding-forum/614408-identifying-911-engine.html)
Pinch 06-16-2011 02:58 PM
I hope I'm posting this in the right place. I would appreciate some help in identifying a 911 engine. I've attached some images and serial numbers. Any info and/or insight would be great. The photo is a little fuzzy but the SN is 6669079.Thanks!
http://forums.pelicanparts.com/uploa...1308261222.jpg
http://forums.pelicanparts.com/uploa...1308261398.jpg
http://forums.pelicanparts.com/uploa...1308261416.jpg
356RS 06-16-2011 03:31 PM
6669079 would be a 1976 3.0L case. The type stamp on the case should be 930/02. That's a very nice case to have.
Pinch 06-16-2011 06:21 PM
Hi Mark, Thank you for the ID. Tell me, why is it a desirable case?
356RS 06-17-2011 08:05 AM
The first two years of the 3.0 Turbo and 3.0 Carrera engine case used the same main bearing OD size as the earlier 2.0, 2.4, 2.7. This allows you to install the early 66 mm stroke crankshaft. The combination of the 66 mm stroke and 95 mm bore gives you the starting point for the popular 2.8 short stroke engine. The case alone IMHO is worth $2000 plus.
Pinch 06-18-2011 01:58 PM
Hey Mark, I can't thank you enough for the info. I reinspected the engine and it is stamped 930/12. Is the difference significant? Thanks again!
tom1394racing 06-18-2011 02:40 PM
930/12 is a '76/'77 3.0 Carrera with Sportomatic transmission
356RS 06-18-2011 03:09 PM
Tom's right. Still the same, but from a sportomatic.
