911 Engine Rebuild
What is a typical engine and trans. rebuilld cost? Car was running and no major issues. 1976 2.7 , 5 speed
Old 01-03-2012, 05:46 PM
AlfonsoR's Avatar
I believe I've seen where Bruce Anderson estimated $25,000 for a shop to do the engine, ball park of course.
It all depends on the condition of the internals and you won't know that until you inspect everything, and 2.7 being a Mag case, right, there will probably be added expense just due to that.
Not sure at all about trans. Why do you think the trans needs a rebuild? It might just need fresh oil and a Wevo shifter.
"Simplicity is supreme excellence" - James Watt
Old 01-03-2012, 06:13 PM
ASE Master Tech - 35 yrs
larrym's Avatar
engine rebuild flat rate labor is 40 hrs - at $100/hr avg
easily gets to $10K quickly just for an "overhaul"
- my local guy gets $6K for a top end only with rings & valves & guides, gskts
assuming you deliver the engine on a crate
$8-9K min complete with bottom end brgs, gskts,
- assumes crank & cams, oil pump & all studs & such are OK
ADD $$$ for timeserts, other case work, studs, etc - much of which your 2.7 will need to be relliable
if you need P&C's add $3K or more
of course, MotorMeister will "do it cheaper"
"... I am German, and if it has no logic it's meaningless."
914 & 914-6 parts FS 03-2021 www.tinyurl.com/2pmpmv8y
911 parts FS 2022 https://tinyurl.com/911-Parts-FS-LCM
Old 01-12-2012, 08:10 PM
