911 Engine Rebuild
What is a typical engine and trans. rebuilld cost? Car was running and no major issues. 1976 2.7 , 5 speed
I believe I've seen where Bruce Anderson estimated $25,000 for a shop to do the engine, ball park of course.
It all depends on the condition of the internals and you won't know that until you inspect everything, and 2.7 being a Mag case, right, there will probably be added expense just due to that. Not sure at all about trans. Why do you think the trans needs a rebuild? It might just need fresh oil and a Wevo shifter.
"Simplicity is supreme excellence" - James Watt |
ASE Master Tech - 35 yrs
engine rebuild flat rate labor is 40 hrs - at $100/hr avg
easily gets to $10K quickly just for an "overhaul" - my local guy gets $6K for a top end only with rings & valves & guides, gskts assuming you deliver the engine on a crate $8-9K min complete with bottom end brgs, gskts, - assumes crank & cams, oil pump & all studs & such are OK ADD $$$ for timeserts, other case work, studs, etc - much of which your 2.7 will need to be relliable if you need P&C's add $3K or more of course, MotorMeister will "do it cheaper"
"... I am German, and if it has no logic it's meaningless." 914 & 914-6 parts FS 03-2021 ![]() 911 parts FS 2022 ![]() |
Thread Tools | |
Rate This Thread | |
