-   -   Which Nut to Use? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/618364-nut-use.html)
930LDR 07-09-2011 09:53 PM
Which Nut to Use?
About to seal up my case (again) in the morning and wanted to confirm that I am using the correct nuts to secure the oil pump before doing so. As of right now I am using the locking tabs and M8 Oval-Shaped Locking Nuts that came in my Pelican Super Parts kit. Any issues? Pretty sure that I don't want to use a nylon lock nut inside the case but wanted to confirm before closing it all up.
Thanks,
Henry Schmidt 07-09-2011 10:14 PM
We use a prevailing torque nut on all oil pump studs.
The factory uses a standard hex nut with a lock tab.
