Pull dist out of 964
I'm going to EFI with my 964 engine and I want to pull the disty and rotor
assembly. I've removed the single bolt that holds it as well as the allen bolt between the pair -- but the disty will not budge. Wayne's book just says to remove the one bolt and it pulls right out. --- I've had the crank at different points of rotation -- and tried with no luck but at the moment I've got the flywheel locked and one set of heads off. any ideas? thanks, Mike |
Hi Mike,
There is an o-ring that seals it but the only physical retraint is that single nut. Have you tried giving it a gentle lever? Be careful though as others have damaged the dizzy casing if getting too physical with it and they're mega $$$ |
Had the same issue when removed mine on my 930. Gentle hits with a rubber hammer up-wards and some WD-40 down the hole helped me. Not a lot of room there I know
Hadn't been that brave yet :-)
I'll give it a little more persuasion the next time I'm out at the shop working on the engine. Mike |
| All times are GMT -8. The time now is 04:54 PM. |
