Installing Flywheel Seal
Is it a better bet to install the flywheel seal when sealing up the case or waiting to install it once the case is together?
Thanks,
Rob Montgomery
'88 Blk/Blk 930 ('Lucy') - Not Stock & Not Running
Old 07-09-2011, 10:27 PM
CaptainCalf's Avatar
Thanks,
I've only done it once, but I did it while sealing the cases. IIRC I torqued the through bolts then installed the seal and after that I then torqued the perimeter bolts/nuts
RC
FS 1987 930 DTAFast EFI w/Electronic Dash, 17x9x11" Lindsey Racing Fuchs, Andial 8.39 R&P, C2 Intake, SuperCup Cams, Flame Ringed Heads & Cylinders, TurboKraft Full Bay Intercooler, RearlyL8 Twin Scroll Headers, Big Bullseye Twin Scroll Turbo...SOLD
1999 Harley Davidson Custom 1250 Hardtail Bobber..SOLD
2014 BMW X6M, 2012 BMW 128i, 2014 GMC Sierra, 2015 Cobia 237 Center Console 300hp Yamaha
Old 07-10-2011, 04:08 AM
I always install the seal when I put the halves together. Its much easier and you dont have to make the seal install.
I put the halves together and install perimeter nuts fiirst because the sealant is fresh.
Bruce
Old 07-10-2011, 05:20 AM
Ended up installing while sealing the case. Went together fine. Nice and square. BTW I opted to install dry as most are now recommending around here.
Rob Montgomery
Old 07-10-2011, 03:48 PM
