Upgrade oil pump
Folks,
I am into the case of my 2.4, while I am in there I am having the oil bypass modification done. Should I look to upgrade my oil pump at the same time or am I good with the original?
Thanks,
W
-Wade
1972 Targa, nothing matching.
Looking for motor 6124265 and transmission 7720299
Old 07-12-2011, 05:26 AM
Try not, Do or Do not
Henry Schmidt's Avatar
Magnesium case engines have issues with oil pressure at idle (especially when hot @ idle) so we always upgrade the pump to aluminum.
We also do a flow modification to the internals of the pump to improve flow.
Every little bit helps.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 07-12-2011, 07:29 AM
Thank you Henry
-Wade
Old 07-12-2011, 08:45 AM
The reason to do the oil bypass mod is so you can use the newer (1976 on) oil pump. The newer oil pump has a larger pressure section and a smaller scavenge section. This will give you more oil flow and higher pressure at idle. If you keep the old pump you don't need to do the bypass mod.
-Andy
Old 07-12-2011, 10:46 AM
Thank you Andy, good explanation. I know much more about my car than I ever planned on knowing!
W
-Wade
Old 07-12-2011, 12:37 PM
^^^ That's the best part of embarking on a rebuild yourself IMHO. The heart of my 911 has always been a complete mystery to me before.... it's slowly all coming together in my mind now as I reconstruct the motor.
Rob Montgomery
'88 Blk/Blk 930 ('Lucy') - Not Stock & Not Running
Old 07-12-2011, 02:00 PM
Henry can you show us the internal mod to the oil pump that you do or is
that a Supertec trade secret?
andy
Old 07-12-2011, 06:04 PM
