Order Online or Call:
888-280-7799
McAfee SECURE sites help keep you safe from identity theft, credit card fraud, spyware, spam, viruses and online scams
Porsche | BMW | Mercedes | Audi | Volkswagen | Saab | Volvo | Mini
  Search Pelican Parts:
View Cart | Project List | Order Status |  Help
Alan L's Avatar
piston ring gap
I went to insert some new 930 rings in the cylinders. The spec sheet says max wear limit ring gap is 8 thou (0.2mm).
When I insert my new rings in the very top (unworn) and lower part of the bore, I still get 12 thou gap - how does that work? I'm reasonably sure the rings dont come in various sizes.
Alan
OK, I read the specs wrong - mixed up ring gap and ring clearance specs. 12 thou is in spec - just, for new ring.
83 SC, 82 SC (Been gonna sell for 7 yrs), 82 930 (track) - Stock except for RarlyL8 race headers, 22/28 T bars, Digi WUR (currently in a box), Rarlyl8 Zork, modified 3LDZ, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust.
Old 07-11-2011, 04:24 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #1 (permalink)
On two engines I've rebuilt, I used the old rings because they had smaller end gaps than the new rings I' had bought.
-Andy
Old 07-12-2011, 09:51 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #2 (permalink)
Alan L's Avatar
On other engines I have done, you haveless than minimal gap and have to grind the ends to open them to minimum spec - with a special ring grinder stone.
So it does seem weird when re-ringing these things you have to start off with more than minimal ring gap - especially for a track machine. Squeezing up the ring gap to the bare minmum (which is usually a secret number to the engine builder) is one of the performance edges builders look for. But not an option here.
Alan
Old 07-12-2011, 11:17 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #3 (permalink)
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
Copyright 2011 Pelican Parts - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
