-   -   cam timing question (http://forums.pelicanparts.com/911-engine-rebuilding-forum/618968-cam-timing-question.html)
ed decker 07-12-2011 08:02 PM
cam timing question
Hi all, this is my first rebuild, sorry if this is a dumb question. i did not separate the cam housing just had the whole assemble cleaned and checked for any problems . Since i did not move anything or take anything apart is the process for timing the cams different . I took the cam housing off at top dead center. thanks ed
Alan L 07-13-2011 12:57 AM
Hard to understand exactly what you have done - you cant remove the cam housing without removing the timing sprockets - in which case you have to re time it.
Alan
boyt911sc 07-13-2011 06:16 PM
Cam timing........
Ed,
What engine are you rebuilding?
Tony
ninesixfour 07-15-2011 09:43 AM
You didn't separate the cam housing from what? The heads? I'm confused...:confused:
lindy 911 07-15-2011 01:30 PM
You MUST re-time the cams, no question.
