cam timing question
Hi all, this is my first rebuild, sorry if this is a dumb question. i did not separate the cam housing just had the whole assemble cleaned and checked for any problems . Since i did not move anything or take anything apart is the process for timing the cams different . I took the cam housing off at top dead center. thanks ed
Old 07-12-2011, 08:02 PM
Alan L's Avatar
Hard to understand exactly what you have done - you cant remove the cam housing without removing the timing sprockets - in which case you have to re time it.
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 07-13-2011, 12:57 AM
Cam timing........
Ed,
What engine are you rebuilding?
Tony
Old 07-13-2011, 06:16 PM
You didn't separate the cam housing from what? The heads? I'm confused...
Gone
92 C2
82 Euro SC race car
993 C4S 3.8
84 Euro Carrera
Old 07-15-2011, 09:43 AM
You MUST re-time the cams, no question.
Tell it like it is or don't tell it at all.
Old 07-15-2011, 01:30 PM
